- Posts
- 6
- Likes
- 0
DaveInLA
·I have an Anniversary Speedy with 1450 bracelet that I haven’t worn in a while. I tried to size it today and the spring bar broke. I’m referring to the 16 mm spring bar that attaches to the clasp micro adjustment holes. I tried using the equivalent spring bar from my 1171 bracelet and it is too thick to fit through the link. I don’t have calipers but to my eye, the 1450 and 1171 bars look the same size but I just can’t get the 1171 to go through.
I don’t need OEM Omega spring bars, but I want an appropriate sized spring bar. There are so many types of spring bars. I think of the double flange ones as being used for the lugs, not the clasp, but if it’ll work, I’m fine with that. What about thickness? The ones that are easy to find are 1.5-1.8 mm thick. Will that work?
