Magnification equipment for changing/sizing a bracelet
I'm in the process of trying to size a newly acquired 1125 bracelet for my late 60's Seamaster.
The bracelet just arrived yesterday and upon inspecting it, I realized that this bracelet uses screws, not pins. doh!
Using the 'fine' tip (1.2mm) of my Bergeon spring bar tool for width reference, it appears that a 1.2mm screwdriver blade will be a decent width to span the majority of the recess in the screw(s). So I'm going to place an order for a Bergeon 1.2mm screwdriver tomorrow. Before I close out the order and pay the shipping on something so small, I'd also like to get something to give me a little better visual fix on what I'm working on.
So my question for you guys is what do you use to magnify the work piece(s) when you're working on bracelets/links?
I'm debating between these two types of magnification aids:
Headband Magnifier w/ 4 different lenses (1.5, 2.0, 2.5, and 3.5 magnification), $24
or
Folding Magnifier (3x magnification), $10
or, I would also welcome suggestions on other contraptions to help me.
Pinky promise: that I won't go full gorilla on the screws and post another thread next week asking for help on what to do now that the screwheads are FUBAR'd. 馃槈 If the first one won't cooperate with light effort, I'll probably just tap out and take it to a watchmaker to have him remove them (along with the thin layer of dead skin cells and other crude that are currently residing in the screw holes. 馃槻
Just go to your local drug store/chemist and get a pair of 3+ reading spectacles.
I use them for general work and only use a loupe/microscope for detailed work like incabloc springs.tiny screws etc.
For sizing a bracelet - I generally use no magnification.
I agree with Archer but if you buy the headband unit, do yourself a favor and spend the money on a real Donigal Optics Optivisor with glass lenses. I find a four plate is fine for casework (and I own four, five and ten). You can wear your normal glasses underneath them for perfect correction.
This is definitely a case of "You get what you paid for".
Great tip! I cruised over to my local drug store and picked up a set of +3.25 reading glasses, for $10. These should do the trick. 馃憤
