Loupe System Model 01 6X Loupe Kit with Hard case, soft case, pouch, cleaning cloth and optional eyepiece. Here is more details from the manufacture: Excellent condition $450 shipped in US The Model 01 loupe provide 6x magnification through five multi-coated optical glass elements arranged in three groups, Designed according to the same principles as a camera lens. The surfaces of each lens has had several special coatings applied to them, which are designed to maximize contrast, color saturation and color fidelity as well as minimize flare. As such, our 6x Model 01, for example, is capable of resolving much more detail than the eye can see (well over 30 lp/mm @ MTF 0.8, versus 5-10 lp/mm at best for the human eye), thus providing a very bright, contrasted and crystal-clear viewing field from edge to edge. The complete absence of chromatic aberration, combined with the very tight control over geometric distortion, provide a breath-taking viewing experience which has never been achieved before in a hand-held loupe. Each loupe comes provided with two interchangeable silicone rubber top elements. The standard one, which gives a 40mm-wide viewing field places the eye at the optimal distance to take advantage of the best optical performance which the loupe can offer. The alternative top element places the eye closer to the loupe, thus providing a wider 50mm viewing field at the cost of a small loss in visual acuity (which - though measurable - is not noticeable by the human eye). Each loupe is delivered with its alternative top silicone rubber element, a microfiber carry pouch, a hard shell carry case, and a microfiber cleaning cloth. All elements are packed in an ABS waterproof case. My Instagram account has some images shot thru the loupe: https://instagram.com/heuerautavia/
I also have the original box and second foam set that converts the pelican style case to a watch box.
This loupe is, probably, the best complement a watch collector may add to its stable. Magnification ratio is perfect, but the best point is no distortion in the edges and absolutely no light loss, so you can use it in poor light conditions with good results.
From the Hodinkee review: https://www.hodinkee.com/articles/taking-a-closer-look-at-the-loupe-system 45 mm high with a diameter of 48 mm, and weighing in at 125 grams (just under 4.5 ounces)
Its in excellent condition, and comes with a great little fitted zipper semi hard case. Then you can convert the larger case to a watch box with the included foam set. The lens cloth and pouch were never used. All in perfect condition.
No just OF'd...this is a great Forum, thanks to everyone that contributes. I've learned a great deal here!
