Thats the problem with some Omega models. In order to use that movement and dial. You need to find the same case
There are places that say they can restore gold filled cases, but I'm not 100% sure on that. Too hot and area will turn black or melt.
When I had some worn cases. I would file a bit and then sand to feather the worn areas into the clean ones and then replate the case. Problem is. Plating does not have the same warm glow of gold filled
Just keep searching Ebay for the reference number. Also Ebay UK, Germany and Italy and maybe something will pop up
DON
