Light box test
Living in a dark house and not always sunny, I acquired a light box to see if I can do better pics.
My skills are bottom rung but with better light maybe one foot up.
A busy dial is probably not the best beginner subject but go big or go home.
Could you tell me a little about your setup for this shoot? What is the lighting? Camera? Lense? Settings?
Thank you.
The main upgrade I made was buying a light box. Or you could probably DIY something like this with a bunch of LED panels.
Camera is just my iPhone for now. One trick I learned is to change the exposure if the watch looks over exposed or washed out with light. You’re better off with a lot of light to pick up as much detail as possible, but if it looks washed out then you dial down the exposure.
I do this by tapping the image I’m going to take to set the auto focus which puts a yellow square in the frame. Next to the square is a sun icon. If you drag that icon up or down you adjust the exposure up or down.
The other trick is do set the zoom to 2x. This gives you a relatively good depth of field and fairly natural perspective. 1x on the iPhone is a bit wide angle and can give the watch that bubble/ fish eye effect.
That’s about it and I just play around with adjusting the lighting brightness and exposure settings. I did find my wife’s old DSLR and a couple of lenses that go with that, but I haven’t tried to go crazy with a complicated camera or lenses yet.
This one was the same set up but swapped the white background with green. The light box kit provided multiple color flexible PVC backgrounds. I recall having to turn down the brightness on the LEDs because I was getting too much reflection off the crystal.
More with a Squale diver. Having the light come from multiple angles definitely helps control glare and reflection issues. Now I probably need to start upgrading my camera capabilities. The middle picture has richer, warmer tone from the background than the other two pics with the same background.
