How Does a 19mm Omega Nato Strap look on 42mm Planet Ocean?
An update here!
Just measured the lug size of my Black & Orange Rule ( 馃榾 ) and it is 21.5mm. I measured also the Black Nato Strap ( Black with Orange Borders ) and it is indeed 21.5mm, which makes a fit and exact match to the Watch.
With regards to 19mm Nato, The one at the OB could be a manufacture Error to have it exact 19mm....Will keep searching and update!
Regards
Hi . I change from the metal bracelet to the bond nato strap on my planet ocean chronograph 9900 regular. I don't mind the extra big height it gives. When I ordered my strap from the shop the chap never mentioned I should use curved spring bars. The strap fits perfectly in between the 22mm lugs with no spring bar showing at all and I'm just using the straight spring bars. Personally I think the watch looks awesome with the bond strap.
Don't know if this helps at all, but it shows a standard 20mm no-name NATO on a 19mm Speedy CK-2998 LE lug, using curved spring bars. You can see in one pic how much the band bows with the help of the spring bars, but then another view where it's hardly noticeable.
Could you tell me who makes this NATO strap and what size it is? Thanks
It鈥檚 the Omega one.
It鈥檚 the Omega one.
I believe It鈥檚 actually a Zulu Strap nato and not an Omega nato. I purchased it from a vintage watch dealer but I believe he ordered them from AliExpress?
I believe It鈥檚 a 20mm Zulu Strap nato? I purchased it from a vintage watch dealer but I believe he ordered them from AliExpress?
Doesn鈥檛 he say it鈥檚 the omega 19-20 in the description?
The OP does, but I believe the post you responded to was one asking about the one in a pic I posted within the thread.
