Hour Vision 433.10 (cal. 8900) - grey market, METAS missing
Hi everyone,
Last week I picked up a De Ville Hour Vision Master Chronometer (blue dial, steel bracelet, cal. 8900) from Eason Watches, dealer in Hong Kong that's part of the HK "No Fakes Pledge" scheme. Came with box and all three cards.
Ref: 433.10.41.21.03.001
Serial: 87843663 (same on the movement, the lug and all three cards)
Warranty card market code: 51110
The situation:
  • The JEWELLER and DATE fields on the warranty card are blank, so I assume it's a grey market piece. I'm fine with that, I mainly want to confirm authenticity.
  • Scanning the Master Chronometer card only opens omegawatches.cn/masterchronometer, not the actual certificate, so I can't see the METAS results. My guess is the watch was originally allocated to mainland China.
  • I asked an Omega boutique in Bangkok to check the serial, but they said they couldn't help.
What I've checked so far:
  • Phone timegrapher: 25,200 bph, around -2 s/d dial up
  • Case thickness approx. 12-12.5 mm
  • Hour hand jumps independently and the date moves back and forth with it; no quick-set date position on the crown
  • Free-sprung balance, "BARREL TWO" engraving, clean finishing
  • Serial matches on movement, lug and cards
Everything looks right to me, but I'd love a second opinion. If anyone with access to.interneal Omega system could confirm that the serial matches the reference, I'd really appreciate it.
  • Has anyone with a China-market card managed to pull up their METAS results?
  • Do you see anything off with watch?
Photos attached. Thanks!
