Hi everyone, need some help identifying the below bezel. The inner circumference fits a speedy pro dial with no gaps. I thought it was meant for earlier Speedmaster mk2. However, a collector friend told me otherwise as he claims mk2 never had dot over ninety. Any help appreciated. Thanks.
The Mk. II "bezel" is actually painted on the crystal, so there's no part like that for a Mk. II. Not sure what that is from, but it's surely not for a Speedy Pro...
Thank you for the information on the MK2. Let's hope someone can shed some light on this bezel. I have googled through tons of photos but nothing seems close enough.
The closest example i can find is the below photo. The dots for each number seems to be of the same position. But as per your advice above, these should have printed 'bezel' as well? Anyone other gurus venture for an opinion? Thanks.
