Yes, the operating lever is the same on all the movements, however there are 4 extensions available for the operating lever (the lever itself is part number 72218611720):
093ST0024 - 0.35
093ST0025 - 0.75
093ST0026 - 1.25
093ST0048 - 1.65
If you order the operating lever kit, part number 7221861999, you will get the lever plus all 4 extensions. You then select the extension that is appropriate for the case and pushers you have.
I have never seen a cross reference showing what cases use what length of extensions. I think you need to keep in mind that the people who wrote this documentation assumed it would be viewed by professional watchmakers. Selecting the right length is just a matter of looking at the gap between the pusher and operating lever, and having something that will fill that gap and ensure that the pusher can be depressed fully, which is pretty simple to do.
