It's hard to tell from the pics but: Looking at the straight on photo, does it look like the "tachymetre" writing on the bezel is a little worn too? It isn't showing up nearly as clearly as the number writing on the left side of the 12 o'clock position. How does it look in real life
@Japenney?
If the bezel writing is worn directly in line with the AR issue, this might be due to some wear post factory. If that's the case, I would send this right back to the seller as I doubt it left the factory in this condition. Or, the diminished bezel clarity is just due to a trick of light and angle. In which case...never mind!
