Help with My grandfather's pocket watch.
Would anybody be kind enough to help with a beginner's question?
Our grandfather passed away 40 years ago. By coincidence we have found his omega pocket watch which wasn't touched since then. It begun working.
Just for our curiosity - how old is this watch? Where was it manufactured? Would you recommend restoring it? We dont mind its value.
Thank you very much.
Based on the case serial number the watch was made some time around 1920 in Switzerland.The number on the movement itself would help to be more certain. A good watchmaker can advise you about possibility of restauration. If possible the dial should not be refinished only gently cleaned and as many original parts be kept as possible. A nice watch, although the seconds hand is missing.
The case looks gold on my phone’s screen, but is marked 925, which means silver. I’d guess it is silver in hand, or gold-plated silver.
As above, a photo of the movement is needed for more answers. I totally understand wanting to restore it for sentimental reasons. I’m looking forward to learning what happens.
Wow, Almost 100 and still working! I Would take it to a watchmaker. I believe as an conservation architect in "minimal innervation". I guess this is also relevant for watch repair.
Thank's.😀
S semah
Thank's.😀
Definitely. Most of what is wrong can be repaired without significantly altering the watch: the movement can be serviced, the case hinge can be repaired, a new bow can be fitted, the hands can be replaced, and you might even be able to find another dial in better condition.
Your first concern should be, how much are you prepared to spend to “restore” this watch! Just looking at the poor, sad dial, and the state of the case, I’m thinking, if the movement similarly needs a lot of work, you might find that you can buy one, running, and in better cosmetic condition in his memory. For less.
This is exactly my thought. If granddad passed away 40 years ago the watch had already seen a very hard life and probably hasn't been used for 50+ years. What would be the reason for restoration of case, dial and movement? Is it going to be used? Probably not. This could be a very expensive exercise to get the watch restored for no other reason than 'it was grandfather's watch'. Doesn't sound like a compelling reason to me. Why not go to Hobby Lobby and buy a small shadow box (8" x 8" or so), get a few other of your grandfather's possesions (pipe, cuff links, lighter, picture of him, and any other personal items that defined him) and put together a nice display which would commemorate his life. Use the watch as one of focal points of the display. My sister did this with my mother's things and it turned out very nice, I have it sitting in my display cabinet. Anyway, just an idea. We tend to immediately think of restoration when we see old watches, but sometimes it just doesn't make financial or emotional sense.
Fabulous idea
Thank you😀
My point of view is neither sentimental or financial.
I am just amazed to find a historical family piece left aside and still working.
Most of all I am curious what kind of watch is it. Where he could have bought it.
Till 1950 he lived in Iraq and then immigrated to Israel.
I guess it is simple because he wasn't rich.
Since my mother also passed away there is no one to ask.
It looks better in reality than in the photo's.
I did open the back side too and it looks shining and new.
