Help with info on vintage Longines
Hi,
I've been offered this vintage Longines. It's 37mm and carries a cal. 12.68zs, which the seller dates to 1958.
What is a fair price for this?
Thanks!
As long as everything is original, I would guess between 500-800$. But I’m sure someone more educated on here can give you a more precise answer.
It's a bit unusual to have the circle cutting right through the markers like that, especially the numbers. I'm more accustomed to seeing the sector boundaries going inside and/or outside the numbers. I'm not saying it's wrong, just not something I've seen before. Have you been able to identify the same dial in other photos?
I think it is fine. Not the first I've seen. The counterpoise on the second hand does appear to have broken off, though.
https://watchcharts.com/listing/130...-wristwatch-circa-1957-6555-8-12-68z-movement
