Help with identifying Seamaster 120m
i can’t seem to find any specific subforum rules so forgive me if this is in the wrong place. I don’t know when the cutoff from vintage to modern is here.
I need help identifying a watch i own, it’s an Omega Seamaster 120m from 1996. I bought it at an auction and on the warranty-card the reference number is 2311.80.00. I can’t add this watch to my collection on Omegawatches using this ref# so I can’t properly ID it. The closest I got to adding this watch is adding 2311.81.00 (indexes instead of mixed on the hour markers)
I left it at an AD to have it serviced and they wrote ref#: 1681501 on the receipt, this didn’t work any better on Omegawatches so now I turn to you.
Also: neither the AD nor an independent watch repairshop that works with Omega watches said they knew why.
Can you provide a photo of the whole card?
Here is the rest of the card (minus the last digits of the serial#)
Not sure what the issue is - your watch is a 23118000 just as the card suggests. Not sure why the AD gave you the 1681501 case number - the case number for this watch is 1961501...
If you want, I can double check the model number, but you would have to let me see the full serial number (you can send via PM if you like). But I see nothing to suggest that this is not a 23118000.
