Without opening the case, is this ref 14395. And cystal pz5005 ???? Case diameter is 35mm Looks like this, but only steel https://www.gmtbroker.com/gallery/Omega/Constellation-Vintage-steelgold-Ref-14395-photo589283.html
If a 14395 the outside diameter without crown should be 37mm. If 34mm diameter it’s more likely to be a 14393.
I think it is highly unlikely. That type of dial is generally a standard size Ref. 14393, with a cal. 561. https://www.ebay.ie/itm/vintage-ome...1-pie-pan-calendar-meister-steel/131528725871Purchases made through these links may earn this site a commission from the eBay Partner Network The jumbo Ref. 14395 is found with the earlier cal. 504 movement. More information here: http://omega-constellation-collectors.blogspot.com/2014/12/the-14395-daddy-of-jumbo-omega.html Hope this helps, gatorcpa
Picture of what? These are all different watches. Check the eBay linkPurchases made through these links may earn this site a commission from the eBay Partner Network that I posted above. gatorcpa
My original photos were poor, but my watch is the same as the third photos watch. It is not the same with that ebay-link, dial is different Sorry my link to dictionary, I cant delete it
The watch you show is a known variant of the 14393, sometimes referred to as a ‘railtrack’ or ‘railroad’ dial. https://omegaforums.net/threads/vintage-omega-constellation-rail-track-dial.36845/ https://omegaforums.net/threads/railtrack-constellation-14393-redial.60827/ https://omegaforums.net/threads/omega-constellation-railtrack-textured-stainless-2250.58098/
