hi all I’ve recently acquired a new UG piece and was hoping to get some help with identifying its year and to check everything seems correct Any info would be appreciated
Good catch, Movement is cal 285 this should put your watch at around 35mm. Left subregister hand is wrong, it should look like the right one with no tail. Replacement is super hard to find but you can try to get your watch maker to take out the tail gently on the left one. “Telesport” is probably a broadcast company or perhaps a short lived promotional name of some sort The watch Dating is per the below serial number table dates it to 1945
Ah yes I see the difference. Appreciate the help. Only other issue I seem to be having is the chronograph feature gets stuck when it reaches 59 seconds
Well for that you will need a full service. You will need to find a good vintage watchmaker and have the UG talk with him.
Reviving this thread - here's a 124146 that I recently picked up also bearing the Telesport text. A few other threads on the topic out there, but no concrete conclusion... https://orologi.forumfree.it/m/?t=71881720
Another thread revival, first time i recall seeing TELESPORT mentioned in a vintage UG advertisement. The ad also mentions the watch is insured if you break it whilst playing sport... unsure if that is specifically referring to TELESPORT or not.
Well, if they offered it for the Climate Proof models then it's not really surprising that they went bust.
