I have recently been given an omega watch that belonged to my grandad. Is anyone able to tell me if this is genuine or how I can find out
Hi Collivier Quartz watches aren't most peoples bag on this forum -but there are some devotees -so best of luck with responses. if no response in a coupe of hours -give you post a 'bump' -our American cousins are just getting out of bed
Yes, its quite genuine. 1342 on the back denoted the Omega caliber 1342 quartz movement inside. Although not a desirable as a mechanical movement Omega, yours is a nice classic design and appears to be in good shape, with a desirable mesh bracelet.
Hi Collivier, Looks like the stainless steel version of this one.......... Gents' leather strap Reference MD 196.0160 International collection 1979 Movement Type: Quartz electronic analogic Caliber number: 1342 7 or 13 jewels Created in 1977 Functions Date Case Gold-plated Case back Press-in Dial With luminous "stick" hands Crystal Armoured hesalite Bracelet Leather Water resistance 30 meters The mesh strap was used on the Omega Chronostop...... Hope this helps. Jack
Thanks very much everyone, the battery needs replacing but other than that it is in immaculate condition. I was advised that if it is genuine the battery must be replaced by specialists and can be quite costly. so wanted to check.
don't need a specialist to change the battery but it may effect the water resistance. Some of the older quartz movements need an insert as the batteries are obsolete now.
