It appears to be a ref 167.005, although the paper in the next to last photo shows 168.005 which would be for the date version.
The watch appears to be in very poor condition with a very heavily polished case and incorrect hands. In the next to last photo the dial appears to have been "cleaned" obliterating the printed second track.
I would absolutely not recommend buying this watch regardless of the price.
If I get a good deal on it
Honestly there is no good deal on this watch, the case is so heavily trashed I don't think anyone would recommend it.
I would want to see really clear head-on pics of the dial.
This dial has a T for tritium and onyx insert doglegs never had lume on the dial.
The single T on the right side would indicate tritium on the hands. From 1963 this was common, I think.
If this were the case, why would the dial you show in your post before last actually have lume plots on the dial? No the single T was just a variation seen around 1963/4 when the first tritium markings began. It doesn鈥檛 indicate lume only on dial or hands which I have see stated as a theory before but is not born out by facts. Here is another original single T watch with lume on both.
This simply isn鈥檛 true I鈥檓 afraid.
There is some debate about Omega supplying 50s Constellations with lume only on the hands but these are more likely to be special order than standard production.
Otherwise, Constellations with lume have it on both hands and dial.
The single T on Constellations with lumed hands and dial runs across a number of years throughout the 60s and appears to be a quirk of the dial manufacturer rather than any considered reasoning.
I see. So what would be the answer to this dial that has onyx inserts without lume dots and the T mark?
I've looked a the dial again and, whilst better pics would still help, I can't see anything immediately wrong with it.
There have been anomalies seen before where non-lume dials have had double Ts but not generally with onyx inserts - these were thought to have been using up old stock or replacement service dials.
If you look very closely at the 'T' is it very slightly higher than the 'MADE', so perhaps it has been added for some reason?
However, I'm with @X350 XJR in that the watch is in poor condition and I think the dial will look worse in person than in the glare-filled photos.
Plus the double indices at 12 don't appear to be aligned and, it may be the lighting but something looks amiss with the 9 index in that you can't see the depth of the onyx insert.
