Grey metallic dial Ed white
Yes. It came in a twisted lug case, so I switched it to a more appropriate straight lug case. Movement looks fine to my untrained eye. 22million serial. In good time I will service it and probably change the hands
So you're reusing the movement from the twisted lug case? Or using the movement that came with your straight lug case? As I'm sure there might be some confusion when getting the archives done.
It's a good question. I bought a grey professional dial speedy that came in a straight lug case, so I just did a case swap with this one, leaving the dials with the movements. From what I've read on OF these dials were probably added later anyways, so they wouldn't be reflected in an extract. Coincidentally they both came with 22087xxx serials, so they are either 105.012s or 105.003s, preferably one of each.
You have two grey dials?
You are sick and twisted...👍
For me, I'd just do a dial swap. Leaving the movements with the cases. So the extract will read more correctly. Or so I hope. As the movements tally with the case. 😀
I don't disagree, but I'm not qualified to do a dial swap myself. Going to order the extracts and see what they say first. I wouldn't be surprised if one or both of them have been spliced together from parts
