Stainless steel contains at least 10% chromium, usually more, which gives it corrosion resistance. Gibeon doesn't have chromium.
But it does have 8% nickel, which would make a normal alloy corrosion resistant, but a meteorite isn't a true alloy, more like a mix, so there is still alot of bare iron exposed unless it was coated. And even so, the coating may not be a perfect barrier either.
I would expect some oxidation over time, a long time.
Or you could fill your watch with an inert gas......![]()
This got me wondering... Has the Seamaster ever incorporated an exotic/rare material from the ocean into its parts?
I suppose something like corals would be quite rare and exotic in a few years.
There are some mother of pearl aka MOP dials out there in the Seamaster line. About a decade old or so. I think most are oversized.
There are also a lot of modern ladies Connie鈥檚 with MOP dials and some Speedy dates as well.
Just take a look at the rust "patina" on this 3 kilograms Iron meteorite... untreated these space rocks rust while You're looking at them 馃榿
They can rust. I've seen a a hread on the Rolex forum pertaining to a persons meteorite dial rusting slightly.
https://www.rolexforums.com/showthread.php?t=456088
Not really very rusty though, wouldn't have noticed if it wasn't circled. Plus this specific timepiece was 9 years old in the safe.
You'd expect it since it's mainly iron but I think Omega do treat the surface with a coating to stop any serious issues. Normally Gibeon meteorites are rust resistant.
Was just thinking about a rusty meteorite dial, would that be called a tropical or chocolate dial? Will they then command a premium over a pristine dial?
Mine looks like new, or is that really old...
