First off, the serial number on the movement is 10293151. This is a Waltham Model 1891 movement, 0 size, 7 jewels, and should have a Breguet style balance spring. 0 size movements were used in pocket and wrist watches. The serial number puts the production of the movement in 1901.
The movement being 7 jewels means that the train has no jewels, and the only jewels are the 4 balance jewels (hole and cap jewels, upper and lower), the roller jewel (also called impulse pin) and this is on the roller table, which is on the balance staff, and the two 2 pallet fork jewels.
When you say it is an "1897 case" is this the year or the model? Keep in mind that Waltham used years for model numbers, so it can be confusing - for example the Waltham 1883 pocket watch I have on my bench was not made in 1883 - that is just the model designation.
Also note that when you bought a pocket watch in years gone past, you went to the store and picked out the movement you wanted and could afford, and then selected what case you wanted to go with it. These were sold separately so you could decide if you wanted to put the money into the movement, or the case, or both. It's possible this was in a pocket watch at some point, and then later transplanted into the wrist watch case.
If it was a pocket watch at some point, it was likely a ladies model.
Hope this helps.
