Can I Swim With My Omega Speedmaster Professional?
I'll explain my attitude toward wearing expensive watches in the water further. You likely won't agree, but that's OK.
To me it's about calculated risk. What is the upside to taking my >$5,000 watch into the water and what is the possible downside?
Upside - I get to swim, or snorkel, or dive with my expensive watch. But how much of an upside is that? Is my expensive watch needed in the water? No. Would I be prevented from swimming, snorkeling, or diving if I didn't wear my expensive watch? No. Could I skip wearing a watch altogether when in the water? Yes. And if the answer to that last question was no, could I wear a much cheaper watch in the water to be able to time things or tell the time? Yes--you could wear a Timex Ironman or Casio G-Shock or one of hundreds of different "cheap" watches.
Downside - The watch company tells you that your watch is safe to go swimming, or snorkeling, or diving. So you should be good to go, right? Probably, but even the "probably" depends on conditions you don't always know with 100% certainty. Are your crowns fully and properly pushed in and/or screwed down? Are your gaskets up to date to be working in prime condition? When was the last time you had your watch water pressure tested? Has your watch taken some unnoticed damage that would compromise its water resistance? As Archer says, a watch is water resistant until it's not.
Why would you take the chance when the downside is a flooded case that requires an immediate service? Or even worse, a small leak that rusts parts inside the movement because it was not obvious enough to know that the water resistance had been compromised. And the water sits in the movement for days or weeks because you didn't realize it? If you have a water intrusion event you are looking at hundreds of dollars in service costs at best--and a total loss of your watch at worst.
If the watch was required in the water, let's say it's 1965 and you are a professional diver, I can see the upside being high enough to offset the risk. But today the upside does not outweigh the risk. Omegas, Rolexes, Breitlings, etc. are too damn expensive to risk given that the upside is nothing more than "Weeeee!!!! I'm wearing my super expensive watch in the water!!!!"
So to me, while you can wear a super expensive watch in the water, you shouldn't. And in my case, I don't. But to be totally honest, I have done it in the past. But it's not something I do anymore because it's not worth it.
*There is one condition where I think it might be worth it to wear a watch in the water. And that would be if you were on vacation with a really nice Omega or Rolex, etc., and you feared taking it off while swimming because it could be stolen (either on the beach or from your hotel room). Then I could see the upside (preventing the possible theft of your watch) outweighing the downside (a water intrusion event).
Ultimately, it's your watch and you are free to wear it wherever you want and to do whatever you want to it. But as for me, I'm not taking my Omegas or Rolexes into the water.
I do agree this is the right solution for you. You did exactly what I suggest anyone should do, you laid out what is clearly a well-informed and well thought out argument for why it is not right for you. This is a great post, and it is exactly what anyone considering whether or not they should wear their watch in the water should read. Truisms (more or less) are what I had issue with- not whatever your informed personal decision was.
For myself, I will continue to wear my expensive modern watches for the activities they are rated to withstand. I purchased them to wear them with the understanding they will need a service at regular intervals to best avoid incident. Although I don't have the same amount of time wearing watches as some here, in 3 decades I've never had any watch have an issue with water intrusion. That can change, but I don't think that it would change my approach. I fully understand these watches are going to need a service at some point.
I appreciate your thoughtful response!
