Can Anyone Attest To This Cleaning Method?
I just bought a jewellers silver and diamond cloth. Scared to use it as I tested it on a gold necklace and it gives a super shine! I think it actually detracts the value...on watches but it's really hard to achieve good results whilst still keeping the sharp edges! I used it sparingly on my gold capped connie and it just brought out the muck and have it a slight lustre....will be v careful though..for instance my cal 505 stainless steel pie pan almost looks as though it hasn't ever been polished, it's got a more brushed effect..don't want to spoil that..
Yes, "Muck" is good to mention. It is very detrimental to watches functioning, appearance and integrity. However muck (usually a combination of aged oil, skin, dirt, barbeque sauce, lotion and salts 馃槻 ) can be cleaned with a liquid non-abrasive cleaner.
The bad cases, generally older, it is best to remove the movement and then clean the case. The best job is with the Crystal removed. I recommend rinsing thoroughly with hot water and then drying well with a cotton towel.
Plus toothbrush and soap while you're at it.
Yes, I forgot to mention the toothbrush.
No matter what - ca' canny 馃榾
I've been using Scrubbing Bubbles on my dive and oyster cased Rolexes. It works great and the foaming agent gets into the nooks and crannies in the bracelets.
Hmmm...never thought of that. Might try it on a low value steel watch case. I've had good luck with a microfiber eyeglass cloth for removing skin oil from normal wearing. When I purchase older watches that haven't been cleaned in a long time, I'll use a toothpick to carefully remove the caked on grime in the crevasses and then a Blitz cloth (avaliable on eBay for as low as $5 - get the blue one only) to finish off.
Note - only use the Blitz on solid metals like gold or steel. I've had some reactions with base metals used on filled and plated cases.
After that, it's back to the microfiber,
gatorcpa
gatorcpa
I use the toothpicks too! They work great with no scratches.
Great around bezel too.
