I have found that I will probably will not get any skinnier as time goes on. So will need a couple links in the future as my bracelet has already stretched some and is on the last adjustment hole now. It is on a 166.028 Seamaster.This is the bracelet I have, I know it probably wasn't original but still hoping some one might have some info to help locate a couple links. The band tapers from 18mm at the watch to 16mm at the clasp, and looks like this.
Looks like it may be another 1175 without a reference number. Mine looks exactly like this one except it doesn't have the reference stamp: http://omegaforums.net/threads/does...-i-have-here-from-my-sm300.10909/#post-127126 Yours looks the same although the clasp inscriptions are arranged differently. Is there a date stamp near one of the clasp hinges?
Thanks for the quick response! Yes it looks just like the one in the link you posted, mine has no date, or 1175 any where on it. So maybe links from an 1175 would work? I might have another problem. The only place I see a removable link is on the side that is already 2 links longer than the other. This is how the link is held in place. And one end of this spring bar come right out of the tube, and it was hell to find in the carpet.
I can't really help except to document my Speedmaster's (replacement) 1175, if that is indeed what it is. Links sure look the same as yours though the number of removable links is different. And the clasp inscriptions are inverted as well as rearranged.
Sure looks the same to me, Thanks for your help. Just searching the net it appears I am hunting Unicorns Bob
