Bracelet Help/Identification FOIS
Hello everyone,
I purchased a used FOIS a while ago, and wear it either on the original strap, or a Fostner flat link.
The seller included a 19mm Omega bracelet that I believe is from the racing series. It is is marked STZ006705, STZ006706, and STZ006707 on the clasp and second link from endlinks.
When trying to use it on my FOIS, the endlinks have too much rock to them, and a gap is formed when flexed downward. This scuffs up the case when worn. Are there different endlinks I can purchase to fit the case correctly? Is this the same bracelet as a 1565/976? I'm not sure how to correct the poor fit.
I'll fix it if possible with new endlinks, otherwise I'll purchase an Ed White bracelet and use my Forstner end links.
Thanks for any help!
Those numbers match the bracelet that came on my 40mm Racing. Can't help on the end links fit + FOIS.
