I'd like to fit a beads of rice bracelet to my C case gold cap Constellation (166.017) but am uncertain about the fit of the end pieces on those I've seen online; they appear to be more curved than the case of the watch at the lugs. Thoughts?
Usually. C-cases are not the same shape between the lugs as the standard round case, but we're not supposed to tell him that until he posts a picture of his watch.
That is because BOR bracelets are designed to fit an 18mm lug width and curve and not 19mm. As far as I know you wont find 19mm end pieces that fit a BOR. The other thing is that in a lot of these BORs there is a permanent row of beads attached to the end pieces. Cheers Desmond
Many thanks. The end pieces are 18mm and the links adjacent to the end pieces are not fixed. The problem seems to be that there is insufficient space between the pin and the outside interior surface of the end piece to allow the adjacent links to move as freely as intended. Watchmaker made some adjustments and the result is, for me, satisfactory.
