Best and durable Omega movement now?
The 8' and 9' series coaxials are very nice to look at.
That has to count for something!
So basically the amount of parts you have changed on 1120 and 2500... You mean the other parts mostly have the same wear and it's nothing different. ? Is it right?
No, when I am referring to changes in parts, I'm talking about the differences in the design of the two movements. When existing calibers were changed from the Siss lever escapement to the co-axial, the amount of parts that were changed varied. So on the 1120 to 2500, not only did they add the co-axial escapement, but they changed the design of the balance spring from being one with regulating pins, to being free sprung. So comparing those two for performance due to the co-axial is difficult because they changed more than one thing.
On the 3303 to 3313, it was already a free sprung balance on the 3303, so the only change made there was to add the co-axial. The regulation didn't change, the beat rate didn't change - so these two movements are the best example to compare what performance gains might have happened just adding the co-axial made. In my experience in servicing both, there was no difference.
They say our co-axial is all about better stability during lifecycle. Is it a myth? Could we say that normal escapement wears pretty much the same?
I don't know who "they" is, but again when I was trained by Omega, they clearly stated that the co-axial escapement was not for accuracy, but for extended service intervals.
From your point of view and your experience did you change less or more parts in 2500, 8500, 3313 in comparison to most other movements like Rolex or ETA movements? Or it's pretty much the same?
Thank you for response!
The rest of the movements are no different, so the only question really is, does the co-axial escapement wear out faster than a Swiss lever escapement. In my experience, the answer is yes. It's rather uncommon for me to have to change an escape wheel or pallet fork in a Swiss lever escapement. It happens sometimes, but it's not common. When I do see wear on something like the escape wheel teeth, it's usually from some sort of abnormal condition rather than normal wear and tear. For example, here's what a normal escape wheel tooth looks like in an ETA 2824-2:
Here's one with very strange wear:
Looking at the pallet fork jewels, you can see why the escape wheel teeth look like they do - the jewels is chipped and was chewing up the escape wheel teeth:
Here's another - from an Omega with a Cal. 3303 - note the "line" down the left hand side of the escape wheel tooth:
Every tooth had a bit of the tooth shaved off - the reason is again a chip in the pallet fork jewel:
But again this is very rare - these are the only 2 watches I've had in with this sort of issue in the last 3 years.
The shape of the co-axial teeth means that they come to a very fine point, and that can wear. Although co-axial is touted as having less friction (which is true) that doesn't mean it has zero friction. If you look at the interaction of the pallet fork jewels and co-axial wheel teeth slowed down, you can see a very sharp tooth going over a very sharp pallet fork jewel. I took this video using my microscope with a co-axial movement in the control holder, and you can see it clearly.
If you set the play back speed of the video down to 0.25X, it becomes clear why these teeth wear. Here's an example of that very fine tip that has worn:
Here's the upper teeth on a 2500C co-axial wheel - you can see the wear:
Since my business has shifted a lot towards servicing vintage watches, I don't service as many co-axials as I used to. However when I see people post photos of the parts they get back from Omega when a service is done, I see a lot of co-axial wheels and pallet forks returned, meaning they have been replaced for wear. This doesn't happen with nearly the same frequency with a Swiss lever escapement.
Now is that a problem? I guess it really depends on how you think about watches and how they are serviced. It's normal practice to replace certain parts at every service, like the mainspring. I also know that on certain movements, I'm very likely to have to replace a specific part, because it seems to be worn on just about every movement I get in. I don't personally believe that makes it a bad movement or design - all movements have weak spots and are a series of design compromises. So is replacing these co-axial parts at every service any different, or a cause for concern? I'm not going to tell you one way or another - it's something you would have to decide for yourself if it bothers you or not.
"Since my business has shifted a lot towards servicing vintage watches, I don't service as many co-axials as I used to. However when I see people post photos of the parts they get back from Omega when a service is done, I see a lot of co-axial wheels and pallet forks returned, meaning they have been replaced for wear. This doesn't happen with nearly the same frequency with a Swiss lever escapement"
Archer, do you think Omega replaced that parts (that returned) because we had exactly wear on them or it could be just updated wheels or forks that are better?
These aren't parts that have been updated typically...
I’m happy to be corrected there and as I was tying it I did think ‘I bet the barrel wear has nothing to do with the escapement’.
However, I stand by my point around an over complicated solution, that restricts servicing options, for an imaginary problem.
Overall, you are making an issue that doesn't exist. I own: SMP 300M 2500 co-axial, SMP Diver 300m 8800 co-axial, Planet Ocean co-axial 42 mm 8500, SMP 300M Chronograph 3330 co-axial. All are in regular rotation, all are periodically checked for accuracy, all have been consistently WELL within COSC standards...no issues at all over many combined years of ownership and wear. Any one of these
you can get parts for...IF THEY EVER NEEDED THEM. Any one of them can be serviced by a competent watchmaker. Just because a movement is different, doesn't make it bad... PARTICULARLY since there is no data AT ALL suggesting "badness".
If it bothers you so much, there are other watches than Omega. GO SHOPPING, be at PEACE...the world hasn't ended...YET. 😉
2500d or any of the 7750 derivatives
Fight me.
Yep, agree. The humble 3330 is the best movement I've ever owned.
Could I ask community, is it ok to buy now a new classical Speedmaster?
I have seen some problems at the beginning and some "oilings" issues in detail from Archer, but couldn't find that thread now 🙁
do we have issues now as well? What about used Speedmaster 2020/2021 ?
Archer, may I kindly ask you about 8800 vs 8900 rotor system? As far as I know the winding system its the first thing that usually tend to fail in auto, ...
8900 series equipped with a plain bearing style mount for the rotor and it goes with zirconium-oxide jewels. Pros: it is relatively quite. While 8800 goes with a ball bearing, which is a little bit noisier but more durable. Is that right?
Also, I have heard from salesman "that winding system in 8900 is more resistant to shock than in 8800, but 8800 is far better from reliability point of view as you don't need oil " .. Could I trust that statement?
The issue was fixed with new bushings as of May 2021.
It sounds reasonable...
@Archer do you know if there was a reason some of the co-axial movements have a 25,200vph rate?
Archer, may I kindly ask you again?
As far as I understand, Omega changed their Co-axial wheel in 8900 (which is from Chronograph 9900). So, all models 8500 after service receive co-axial wheel from 8900. Is it just an update or because old one doesn't work properly? What do you think?
Maybe you know, do they apply the same for 2500?
What is the purpose to put co-axial wheel from Chronograph with different beat...? to me it looks a bit unprofessional
Not sure where you are getting this information from, but you need to find a better source - the source you have is a bit unprofessional...
The 9900 co-axial wheel is not used in either the 8500 or 8900.
All 8500 and 8900 models use the co-axial wheel from the 8500G version of the movement, which was the first 15,000 Gauss movement.
This has nothing to do with the 2500...
Archer, thank you so much for reply!
Then I need to ask where the information comes from...
Originally calibers 8500a and 8500b have co-axial wheels that look quite the same as in 2500.
While in 8500G and 8900 they have the new one! What I am saying, that old 8500a or b after service receives new co-axial wheel like in 8900. What do you think about this update? Technical issues?
Do you think the co-axial wheel is a critical part as well that could be magnetised and affect the watch accuracy (or it's not about that)?
Sorry, for too many questions!
"Look the same" and "are the same" are two different things.
Again, all 8500/8900 get the co-axial wheel from the 8508G, which is the fully anti-magnetic co-axial wheel.
This is from the parts listing for the 8900:
7228508G30040 | CO-AXIAL WHEEL
Omega certainly did, which is why they made the wheel and the pallet fork from anti-magnetic materials.
Thank you again!
Except that wheel and pallet fork do we have any other very critical parts that affect magnetism? Or that's almost all we need?
I am just trying to understand they make changes: a) because it's simply antimagnetic issues; or b) technical issues
Balance spring and balance staff.
In 8500b the Si14 balance spring is already there but the balance staff is not antimagnetic? Right?
Do I understand right, that updates are not applied for caliber 2500 like for 8500? So, for aftermarket purchase it doesn't matter which year to purchase caliber 2500? Right? If no updates any more.
Yes.
2500's are not updated with new designed escapements.
Yes.
So, if we saw the parts returned from 8500 series it means just an update to escapement? and not because it has wear on it or wear on it?
However, they often leave the old pallet fork on 8500 series and to me it sounds like the co-axial wheel has wear and that's why it's changed. If it was a simple update they would change a pallet fork as well and those two parts work together, but they didn't.
I just want to understand all these how good that calibers ...
Also, you change the date wheel on 85/8900 but Omega doesn't.
If the watch will fail after two years warranty will they charge me the full price for repair and I will need to pay? Or I have a chance to ask for a free service?
If so, than your independent service is all the way better...
Maybe you know where I could read about other parts that refer to balance staff?
In simple terms to me antimagnetic parts are balance spring, balance wheel, escapement parts - co-axial wheel and fork and that's all I guess.. so would be happy to see what else I miss.
I am sorry for asking too much and as a customer I should know maybe less but I am very interested.
I can't understand what you're getting on about.
All watch movements wear.
Sometimes watches break.
Sometimes they're not covered by warranty.
Omega will replace worn parts as part of routine service free of charge. Of course, the service itself costs a base price but worn movement parts are replaced. Hands, dials, bezels, etc. are at cost.
The cal. 8500 went through several changes; 8500A co-axial, 8500B Si14 spring antimagnetic co-axial, 8500G full Si14 components Master Co-Axial.
The newer calibres you're talking about are resistant to magnetic fields <15,000 Gauss. Full stop. This is by way of a number of functional parts of the movement: pallet fork, mainspring, co-axial wheel, balance staff, etc.
