Delta of 92 seconds...well that's quite a bit. Could certainly be a poise error since all that variation is crown up/crown down, so opposite each other in positions. Of course looking at concentricity and flatness of the balance spring should be done as part of every service, so not sure what you did there. Also looking at the regulating pins, how they are spaced, and how the spring is centered between them is important. I would also check the regulating pins to make sure they are parallel - you have a fairly large difference dial up and dial down that could be caused by this with all else being good...
