Advice please on OEM crystal diameter for UG Clapton 881101/01
Advice needed please from the forum-
would anyone know the original crystal diameter or the detailed spec of the crystal for the UG Clapton 881101/01 ?
Many thanks,
cakral
Not planning to start pirate business...
Reason being, the Clapton i own has a service crystal mounted from a talented or desperate watchmaker- it does not fit properly. I guess finding an original crystal is impossible- but knowing the spec I would at least know what to look for.
Thanks for your help,
cakral
There’s several replacement crystal (non oem) listed on eBay, but not sure if that helps you
Have you tried to measure the diameter on yours with a set of calipers...?
