- Posts
- 77
- Likes
- 43
maximilian g
·hi
I have found a 60s 165 024 seamaster 300 case and the non screwdown pendant case tube is damaged at the end where it fits into the crown....
I have managed to find a screwdown pendant case tube and a new screwdown crown to replace it.
Please may I have advice how to remove the pendant tube from the case. The replacement screw down case tube looks like it is pressure fitted as it appears smooth? if it can be removed is it a push fit for the replacement tube?
I inherited lots of watch/ clock parts in boxes years ago please would someone let me know if there is a spacific tool to remove a tube.
as the end is damaged should i cut the damaged bit of and then extract the remaining bit?
The end is crushed by what looks like pliers?
Please help, advice would be most helpful.
thanks.
max
( sorry about my spelling im dyslexic)
thanks.
max
