One of a myriad of "make your own" watch brands of the 1960s that disappeared nearly as quickly as they appeared.
As noted uses a good quality movement but with an unknown service history you could easily find yourself upside down value wise if it needs a service.
Case shows noticeable wear on the edges of the lugs as well as on the pushers.
Appears to be all original. Will need a case back gasket before wearing.
