[Advice] Omega 14k GF Cal 354
Any crown, even one that is only similar to the right crown, will be better than the present one.
Personally, I wouldn’t send it to Omega If you’ve looked at advice given on similar threads, you’ll understand why.
If you post the area where you’re based, someone on OF may be able to recommend a local watchmaker with the ability to sort out your watch for a reasonable price.
Yeah I’ve read up on that I just wasn’t sure if any watchmaker usually sources crowns and stuff. Will do thanks! What sub form should I post in?
This one should prompt a response. Good luck.
