ctime3
·39.5mm.
39.5mm.
This isn't any cause for panic or to avoid a specific movement - it's part of the growing pains that movements go through over their life span. If you compare a Rolex 3135 made back in 1980's when they were first introduced (to replace the 3035 that had even more problems and was discontinued fairly quickly in Rolex terms) to one made very recently, they won't be exactly the same because specific problems that appeared from longer term use were resolved with design changes. All companies go through this kind of thing to one degree or another, and Omega has been here before fairly recently with the 2500 movements - the problems with those appear to be far more widespread than this one is from what I've seen so far, and no-one issued a recall back then, and I'm pretty sure they won't now.
Nice at first I was like way too smalll and it's about the same size as the 300 justva smidge taller
So if this issue (or others) results in a movement "update", do watches automatically get new parts during their next service, sort of like a technical service bulletin for cars, or is it presented as an option to the owner at service time? I suppose warranty status would make a difference too, but I'd like to think I'll be able to take advantage of any updated parts etc. for my 8800 down the road.
It's essentially a 40mm watch, which is a very classic and versatile size. The case thickness is mitigated by the way Omega did the end links, especially on the bracelet. I ended up with the bracelet and strap, and it's giving my Speedmaster a run for its money on which watch is my favorite (but shhh... don't tell anybody...)
Omega keeps a list of "mandatory upgrade" parts for each caliber, so they do have these sort of hidden recalls like when you take your car to the dealer and they replace some things, but they are not serious enough to warrant a full recall where they send you a letter to bring the car in, so they just do it next time you are there. This does not rely on the watch being under warranty or not - the changes are done regardless.
There are also part exchanges that happen only when they show evidence of a problem. The DLC coated barrels and the balance with the jewel problem are only changed if the item shows evidence of being defective, so it's not an automatic swap. The problematic jewels shown above are an automatic swap no matter what during service.
These kind of changes don't result in a new movement designation by the way, they are just updates to specific parts.
One of my pet peeves about products these days (and I review cars and motorcycles for a living) is the whole "let the customer be the beta tester" thinking. I think part of the problem is a reliance on computer models to simulate real-world wear and tear, and there are always limitations that get overlooked and therefore failures once products are released into the harsh environment of human beings and the things they do. For example (and I have to say so far, so good) is the durability of silicon hairsprings. There's no way of testing how many years they will work and stay within spec under simulated conditions-they just have to be in the wild for years to see what happens. I've not heard anything that would indicate there's a problem, but my point is there's really no way of knowing if the spring will last ten, twenty years of continuous running under varying temperatures, vibration levels, shocks, etc. until its actually done it. Both Omega and Rolex have produced new movements the last few years, and I can't help but wonder how long these things were tested before being launched in watches. Certain things (like clasp testing) can certainly be accelerated to indicate weak points, but a lot of things can't. Anyway, there's always a potential for problems when anything as complex as a new watch movement is launched. Just be glad these are watches and not cars or motorcycles with new designs and/or technologies. Hoo boy. The things I could tell you. . .
This problem is apparently affecting all of the highly anti-magnetic calibers currently. Not sure what the root cause is, or how widespread the problem is though.
