20mm Uncle Seiko 1171 Bracelet for Omega Speedmaster Professional
For sale is a 20mm Uncle Seiko 1171 Bracelet for Omega Speedmaster Professional in excellent condition. This is the long version, adjustable from 130mm-190mm. It is currently sized for my 7" wrist with six links removed (and two more links could be removed for smaller wrists).
$65 shipped to US only. I will cover PayPal fees. I've had 250+ good transactions on this and other watch forums and eBay feedback is available under the same username (where I've had 2000+ positive transactions). No returns unless the condition of the strap is materially misrepresented.
  • Lug width to Buckle: 20mm to 16mm
  • Length (mm) : Long- 190mm, Short- 175mm
  • Min.length after adjusted : Long 130mm, Short 115mm
  • Buckle : Stamped 316L Stainless Steel 16mm Pressure Clasp
  • Thickness (mm) : 3.5mm
  • Net Weight (gram) : 56
  • Finish: Brushed
  • Spring bar diameter: 1.8mm
  • Lug end style : Standard (Hollow) Curved End
  • Adjustment type : Pins
  • Material : 316L Stainless Steel, all solid links (standard end links)
  • Designed to fit : 20mm Speedmaster, also some Seamaster models
