1947 Omega Watch Identification Help - Vintage Omega
Buenas tardes! gracias por su tiempo. Les escribo desde Buenos Aires, Argentina. Tengo este reloj Omega por lo que pude averiguar sería del año 1947. Entiendo que su caja pudo haber sido de oro pero ya no esta. Necesitaba saber si tiene algún valor? si hay mercado para ello? Desde ya muchas gracias.
Hi Tango,
I’m afraid that you’ll probably have to post in English to get any feedback on whatever it is you’re asking.
As you’ve probably noticed from all the other threads, this is an English language forum 🙂
Hola Tango,
Me temo que probablemente tendrás que publicar en inglés para obtener alguna respuesta a lo que sea que estés preguntando.
Como probablemente habrás notado en los demás hilos, este es un foro en inglés 🙂
¡Muchísimas gracias, amigo! ¿Cómo lo edito?
Good afternoon! Thank you for your time. I am writing to you from Buenos Aires, Argentina. I have this Omega watch so I could find out it would be from 1947. I understand that your box could have been gold but it is no longer there. I needed to know if it has any value? If there is a market for it? Thank you very much in advance.
Based on the serial number, the watch would have been made around 1949. The dial was refinished at some point and this would hurt the value. Also, a movement without a proper watch case would not have a high value. Maybe just for parts.
Hope this helps,
gatorcpa
Good afternoon! Thank you for your time. I'm writing from Buenos Aires, Argentina. I have this Omega watch, which, from what I've been able to find out, is from 1947. I understand that its case may have been gold, but it's no longer there. I need to know if it has any value? If there's a market for it? Thank you very much in advance.
It's missing the screws for the winding bridge and one for the gear bridge, but movement is clean
If the balance is good (moves back and forth and hairspring not damaged).
It has value. Maybe $150 on or about
Le faltan los tornillos del puente de cuerda y uno del puente de engranajes, pero el movimiento está limpio
Si el volante está bien (se mueve de un lado a otro y el espiral no está dañado).
Tiene valor. Quizás unos $150 aproximadamente
