Whats required to replace the crown tube on a MKII Speedmaster?
  1. pascs Sep 20, 2014
    I picked up a well priced MKII Speedmaster case but the previous owner has damaged the crown tube. How do you go about replacing these?
    Any info appreciated, thanks
  2. Stewart H Honorary NJ Resident Sep 21, 2014
    I'm not sure with the Mk II but the tubes are either screwed or pressed in, so if you get the new one first, you will know.
  3. Archer Omega Qualified Watchmaker Sep 24, 2014
    It's a pressed in case tube.
    fskywalker likes this.
  4. pascs Sep 29, 2014
    Al, any advice on how to replace it? I assume a special tool is required?
    thanks
  5. JimInOz Melbourne Australia Sep 29, 2014
    Two choices.
    Estwing or Archer.
    My recommendation is Archer (or his equivalent in your locality).
  6. Archer Omega Qualified Watchmaker Sep 29, 2014
    There are specific tools for pushing case tubes in and out. You can also try inserting a large cutting broach into the tube, giving it a light tap with a hammer so it grips the inside of the tube, and then turn the broach to remove the tube. Heat may be required to soften any adhesive that might have been used.
  7. ulackfocus Sep 29, 2014
    A watchmaker.
    Drive to your watchmaker's shop with the watch and tell him/her that the crown tube needs replacing.
    Sure, any time!
    ron n likes this.
  8. pascs Sep 29, 2014
    Where's the fun in that :p
    Also there isnt any watchmaker locally which I'd trust
    Spacefruit likes this.
  9. cicindela Steve @ ΩF Staff Member Sep 29, 2014
    I've got a roofing hammer you can borrow, do it yourself is the way to go :thumbsup:
    pascs likes this.
  10. pascs Sep 29, 2014
    I think it will be DIY .............I do have a couple of big hammers if things get tough :D
  11. DLT222 Double D @ ΩF Staff Member Sep 29, 2014
  12. pascs Sep 29, 2014
    hahahaha :thumbsup:
  13. ulackfocus Sep 29, 2014
    Hey now, don't be moving in on my tool turf! :p
  14. John R Smith Sep 30, 2014
    Well, these pendant tubes are actually a very inexpensive part. So if you trash one in the process of learning how to fit it, it's not the end of the world. Just be sure that you protect the case adequately from the slings and arrows of outrageous fortune . . . ;)
  15. fskywalker Dec 12, 2018
    Al: Does the same applies to the Seamaster professional case (2531 / 2254 / 2264 etc)?
  16. Archer Omega Qualified Watchmaker Dec 13, 2018
    Depends on the specific model, as some are press fitted and some threaded. Even within a model it can change over time...
  17. fskywalker Dec 13, 2018
    Thanks Al; have a Semaster 41mm that the crown does not screw in correctly so will have to get it fixed soon; wonder if it is pressed fitted or screwed like this one shown below:
    Edited Dec 13, 2018
