Typically it's a 120 (1.2 mm) screwdriver, but that depends if the correct Omega screws were actually used. Of course expecting screwdriver blades to fit right out of the box a bit optimistic. Blades often must be dressed to fit the slot of the screw you are working on at the time, so even if you order a screwdriver of the correct size, it will still likely need a touch up to the fit the slot properly.
Can I ask if you have ever removed and installed a movement in a watch before? If not, I seriously suggest you send it back to the person who assembled it, or find a competent watchmaker to do the work. While this is a very easy task for a watchmaker, for someone who has never done it there are many opportunities for you to do damage.
Are you absolutely sure the marks are on the inside? Have you tried polishing the outside of the crystal just to be sure it's not scratches on the outside that you of course just can't wipe off?
Even if the marks are on the inside, you won't have to replace the crystal - the crystal can be polished on the inside as well.
