If you can borrow a digital caliper, and measure the crystal again, it might help. Or better yet, clean out the recess in the case, and measure using the same caliper. I have a cushion shaped glass crystal which fits a Gruen model ( the container in my assortment is marked for a Gruen) that is within about 0.5 mm in every dimension compared to the numbers you gave. It might be worth a look see. Be certain to reset the caliper to Zero before you measure. If you’ll do that, i’ll take another look at this crystal.
