witch stem and crown for cal 552 case ref 14702
i have a geneve automatic ref 14702 with a replacement crown. I am looking for a original crown with stem to replace. What type of stem and crown do i need for this?
here are the photos of the witch stem and crown
I had this in mind... You're a bad boy. 😀
I am poorly behaved today. OP, kindly post your own photos 🤔.
Although, and with respect, I suspect that if you need to ask your question, then you should just take it to a watchmaker that can source the correct parts and install them correctly.
There are forums for the above and I think it calls facebook...
This is a chatty forum. Without banter it wouldn’t be the same.
