Who Should Fix My Watch? How Much Should it Cost?
Sending to Omega and then off to Swiss Alps sounds like 4 months.
I would that is consideration possibly.
Tried checking, is the Seamaster movement one destined for the Swiss Alps?
In the US, there was a long tradition of jewelers selling watches and also having a watchmaker. Some still do. In fact, the local Rolex dealer is a jewelry store, and they have two watchmakers on staff.
I guess that tradition is not universal?
In France a lot of jewelers sold watches indeed, some still do. But IMHO repairing them is a specialty; it is not obvious to a lot of people, always wondered why.
Absent the alleged damage, no. But if it is the mainplate.... but you definitely need a second opinion.
Contact a service center using the information on the Omega website. Ask them for instructions.
Contact NJ Service Center (877) 839-5224 ask for Customer Service. Explain your issues and I believe they'll take care of you.
A broken main plate? Well, although there's I suppose a theoretical possibility of such a thing happening, I will call BS on this.
First, I've never, ever, in all my years seen a broken main plate. That doesn't mean it can't happen, but I've seen a lot of weird shit happen inside watches, and that hasn't been a thing (yet).
Second, if it was a broken main plate, the main plate is essentially the middle of a sandwich of parts. The top of the sandwich is the dial, and the bottom is all the bridges that are placed on top of the main plate. I can't imagine that the main plate can rattle in any way if it is broken. The bridges would actually help keep it held together.
Third, to know that it is a broken main plate, the watch would have to be completely disassembled. If they haven't already taken it completely apart, they have no way of knowing if the main plate is broken. If they have taken it completely apart, ask them to send you a photo of the broken main plate.
So either the shop is straight up lying, or someone has used a term incorrectly. The most likely thing from this movement that would cause a rattle, is of course the rotor. Has the rotor axle snapped, or the ceramic bearing been damaged? Yes, both of those would cause a rattle, but not a broken main plate.
So I suspect that whatever is actually wrong with this watch, would be covered under Omega's normal service price. Omega is the place to send this, and since it will be a paid service
I would definitely send it to Omega. Their $550 charge does include "replacement of worn components" according to their website.
My papers?
‘In April 2016 I purchased a brand new watch--the Omega Seamaster 300 Titanium. It's a gorgeous watch--it has the blue face, retro glow-in-the-dark hands, and the transparent back case.’
You kept your paperwork I hope?
I thought I lost it, but I just found it!
Hi Al,
Thank you for the feedback.
It turns out the local jeweler sent the watch to a watchmaker in Plymouth Michigan called "On Time Watch Experts." https://ontimewatchexperts.com/
I just got off the phone with the watchmaker. He says he has 35 years experience and does in fact have a parts account with Omega (as well as Rolex).
He says the actual problem isn't that the mainplate is broken. Rather, he says there is a screw in the mainplate that "holds a bridge" that sheered off, leaving a piece of the broken screw in the mainplate. He said that although it might take him a couple of hours, he could remove the broken screw and replace it with a new one. He says that if we send it to Omega, in all likelihood they will simply replace the mainplate and it will end up costing more than the $1,700 he quoted.
Would an unattached bridge cause the rattling in a watch that otherwise seems to work?
I told him that I want a second opinion from Omega, and he said that was fine.
Assuming this updated description makes sense, what would you do?
Hi Al,
It makes more sense than a broken main plate - if it would cause a rattle or not would depend on what bridge it was. The screw can be removed easily - pretty routine stuff.
I doubt that Omega would charge for the main plate.
I would think, but don't quote me, for $1700, Omega can replace the whole movement and still make a profit.
I'd still be taking my chances with Omega in this case.
If it's easy to remove the broken screw, then the whole thing should fit into their $550 maintenance deal, right?
I'll let you know what Omega says.
Any watchmaker working on their own would remove the broken screw. However in service center setting, they won't take an extra minute for anything, so rather than repair things that might take a little more time, they just replace the parts. Their priority is getting the watch serviced as quickly as possible, not saving parts...
Would they surmise the watch was dropped, or would more stuff break before a screw?
Can I predict what they will think? No, obviously not.
However if there is no external evidence of an impact I think they would have difficulty proving it.
Normal airmail packages for Switzerland only take 4-5 days - often less than shipments to the other coast of the United States. I used to work in a library trying to get books that people naturally needed yesterday, and sometimes airmail from an efficient publisher was faster than a US distributor even if they had it.
I don't think sending watches to Bienne really requires a mountainclimb with Maria, a goat, and a yodeling shepherd.
