What is the point?
Can't comment on the OP's mental state per se, but the posting itself is a (slightly) paranoid view toward big business with a touch of scapegoating, a common component in that style of viewpoint. (They're out to get me, and it's their fault if things go sideways, not mine)
That will be $350. 😁
Damn, tree fiddy!? I only charge the 5 cents like the sign says. I take Venmo, PayPal, Zelle, CashApp, Wire Transfers, IOUs, favors, etc.
I got into watches, as I like fixing things. (I actually wanted to replicate a mechanical doll. And discovered she was made by watchmakers.)
There is a trade off when choosing which watch to service. Opening the watch involves risk. As does disassembling the watch. It is easy to kink the hairspring.
I also tend to go hot an cold on things. I set aside watchmaking for 20 years or so. Mostly as I had taken on a task to difficult. There was also the issue of parts availability. I needed a spring for a ladies watch. I figured the world of mechanical watches was as dead as My friends in the NAWCC. That the internet was only for scammers. Because no one cared about watches other than Rolex. I do not consider Rolex watches.
Granted I still had respect for Omega, and liked seeing the brand on a billboard nearby. Same for Tag/Heuer. This respect was more that I already had nice examples. New watches were well outside my income level. (edit; And only valued for their gold and visible jewel content.)
I joined these forums as I wanted to find someone local who could service my Speedmaster professional. I did not trust the Hardware store watchmaker. I sort of had an ideal I would like to get it factory serviced.
I then decided I was wrong about the repeater that I need to make parts for. Full time work in it's own right. That I had other projects which I set aside till that was completed. This was actually creating a block. Keeping me from doing what I wanted to do.
So when I opened the tin containing the Landeron 48 after posting a photograph. I decided the repeater was not really something I wanted to do. This on the other hand opened the floodgates. I spent all the money I saved for having the Speedmaster serviced on additional project watches. Notably more ladies omega watches.
Now once again I am in over my head in watches. Other projects have suffered. Last spring it was cameras. Before that restoring a Kodak Photo CD player. And of course the pipe organ stuff that had replaced my watch passion. (The clockwork doll plays a small pipe organ.)
Even if I never bought another watch. I would still need parts and consumables to keep the watches I have working. While 30 years ago I could make the parts, I now find that so many were made, that they are surprisingly available. More so than they were 20 years ago.
If anything the watchmakers and material houses did it to themselves when they flooded the markets with parts 60 to 70 years ago. Then the whole quartz thing happened and the parts were not needed.
There were so many parts from the prior 200 years that in the late 1990s young people started to use them for art projects and costume wear. (steampunk.) This in turn lead to an interest in what this bling was.
Still we have the question of maintainability. Also quantity over quality. I chose the former. Many here would rather have one good (and practical watch) compared to 100 or more serviceable examples.
Now when I look at a watch I see a 400 to 1200 service fee. I think others are seeing this as well.
At the same time, there just is not anyone I can trust , including myself, with the watch I do value. (The speedmaster.) I am also noting the chronostop I use, is probably in need of a service. There simply is no one in my area who can afford to work on such things without sending it out. I want magical service for such things. Someone who can restore the space rating so not only does the watch keep good time (which it still does.) but that all the gaskets and seals are top notch. I also respect the dial hands and bezel, and would not want them changed.
The rest of my collection I can work on myself.
Yes, to get a parts account you have to be Omega certified. If they are not, they are obtaining Omega parts on the open market from resellers, which means they are likely paying more for the parts, and charging people more for them to cover that additional expense.
Will probably service less, leave it till it stops or can’t keep time and let an Omega trained independent do it. I don’t think they charge extra for parts, as long as it is not a dial or crystal. Would love to service every seven years but over next 15 20 years prices will go through the roof. It is only a base model DeVille.
I find what happens in many places is watchmakers that end up going independent after working for or with a large AD or chain that is Omega certified tend to maintain that relationship with their former employer and handle overflow work or covering for them when they have staff away at favorable rates in exchange for having an under the table access via them. I don’t know how concerned the brand is about people doing that but its an arrangement I know a few guys have.
10 years ago service £330. With Russia etc…. Excuses will be found to put all up a lot
Do you envisage becoming increasingly worse off as time progresses from a wealth perspective? If you do then you’re right in your plan to only service the watch if it breaks. If you don’t think you’ll become worse off then I would enjoy your watch and put the service issue on the back burner until it gets closer to “needing” one.
I service my watches every 5-7 years. Most of my collection is vintage Omegas from the 1950s and 1960s. I use an independent watchmaker who is Omega certified and has a parts account. He has no problem getting the parts he needs to service my watches. Just because Rolex doesn’t want to support servicing of its older doesn’t mean that Swatch will do the same for Omega. As for your watch, service it when you see fit to do so. No need to use Omega for service if you don’t want to.
