uvalaw2005
·For sale is my excellent condition white dial Weiss 38mm Standard Issue Field Watch. Minor surface wear with some strap-changing marks on the rear of the lugs. Handwound movement is assembled by Cameron Weiss in Los Angeles. Manufacturer warranty runs through June 2021.
$775 shipped to US only. Payment via PayPal (I will cover the fees). No trades, please. I've had 250+ good transactions on this and other watch forums and eBay feedback is available under the same username (where I've had 2000+ positive transactions). No returns unless the condition of the watch is materially misrepresented.
Movement: Weiss Watch Company Caliber 1005 mechanical movement, 7001 base, finished and assembled in Los Angeles, California from Swiss parts
Functions: Manually wound, 21,600 beats/hour, 42 hour power reserve, hours, minutes, sweep second hand at 6, incabloc shock protection
Case: 316L stainless steel, 38mm diameter (not including crown), 46.6mm lug end to lug end, 9.7mm thickness from the highest point of the domed crystal
Weight: 54 grams with strap
Caseback: Sapphire crystal and 316L stainless steel exhibition caseback, secured by four 316L stainless steel hex screws
Dial: Machined naval brass finished white with high visibility black numerals
Hands: Black oxide treated steel with white Super-Luminova paint
Front Crystal: Double-domed and beveled sapphire with multi layer anti-reflective coating on the inside surface
Back Crystal: Beveled sapphire
Water Resistance: 330 feet/ 100 meters
Band: 20mm olive green, waterproof, lined Cordura canvas, and 18mm 316L stainless steel buckle
