Wearing an Omega in a hot tub/sauna?
  1. ScottyCameronNut Jan 17, 2017
    Tried running a search but couldn't find the answer I was looking for.
    I own a Speedmaster Professional and a GSOTM. Is it safe to wear either of these in a hot tub or sauna? I was recently at a boutique and the employees were a little weary of doing so. Then I went across the hall to a Rolex boutique and the guy told me "We encourage you to wear your Rolex in the hot tub ;)"
    Now I understand Rolex and Omega are completely different watches but am just hoping to get a clear answer and maybe some input as to why Omega couldn't handle either environment.
    TIA
    -Eric
  2. watchknut New watch + Instagram + wife = dumbass Jan 17, 2017
    Anyone like fishing...trolling?
    emilio likes this.
  3. Canuck Jan 17, 2017
    For a very unclear answer as to whether you are safe wearing your Omega (either one) in water, check the message board archive re: wearing a Speedmaster in water. After reading about the topic, you may still not have the final answer.
  4. ScottyCameronNut Jan 17, 2017
    I'll take a look. Thanks!
  5. ScottyCameronNut Jan 17, 2017
    Quite a dumb question ::shy::
    Thanks for pointing me in the right direction.
    Still trying to learn the ins and outs of different watches and capabilities.
    We all started somewhere, right?
  6. Foo2rama Keeps his worms in a ball instead of a can. Jan 17, 2017
    Just don't. The heat may not be good for the seals.
  7. Canuck Jan 17, 2017
    Every water resistant watch that leaves the factory truly water restistant, will be water resistant, but only under some conditions, until it LEAKS. Sorta like playing Russian roulette!
    tyrantlizardrex and Foo2rama like this.
  8. yinzerniner Jan 17, 2017
    And make sure to bring a friend or two while wearing your watch.....
    emilio, Nitzbar, River and 5 others like this.
  9. ScottyCameronNut Jan 17, 2017
    haha
    Ya ya ya. Rookie question ::facepalm1::
  10. Larry S Color Commentator for the Hyperbole. Jan 17, 2017
    And some Raclette......:D
    Lonestar and Jwit like this.
  11. gemini4 Hoarder Of Speed et alia Jan 17, 2017
    I wouldn't risk it. Messing up your Omega, in a hot tub, could be very embarrassing.
    Problem Solved: Run the Omega through a dishwasher a few times before you hit the hot tub.::psy::
  12. OhMegaMan Jan 17, 2017
    Are you doing these in the hottub? Then the answer is dont.
    [​IMG]
    [​IMG]
    Spy, watchknut and abrod520 like this.
  13. LouS Mrs Nataf's Other Son Staff Member Jan 17, 2017
    Really? How long had they been in there?
    MMMD, Vitezi and timjohn like this.
  14. Tubber Jan 18, 2017
    OK, I'll bite. I have worn a Speedie in a Sauna, a hot tub, a Jacuzzi and the sea a few times, inadvertently, mainly due to alcohol. The glitter ball and mirrored ceiling make the dial hard to read. I would recommend a more legible dial like a Seiko Diver.
    Nitzbar and 1685 like this.
  15. Omeg@007 BLACK & ORANGE rule!!! Jan 18, 2017
    For fun and relaxation i believe it is ok, but living there will be.......lool
  16. Spacefruit Prolific Speedmaster Hoarder Jan 18, 2017
    I did.
    Ruined the watch
    Worth every penny....
    kleungsf, drhex, Lonestar and 2 others like this.
  17. tyrantlizardrex Jan 18, 2017
    So a few things going on here:
    1 - your Speedmasters are water resistant to a certain level when new. They only keep this level of WR if the seals are checked/replaced as per scheduled maintenance (which fluctuates depending on the conditions you wear the watch in).
    2 - Rolex is not the same as Speedmaster. You're comparing a brand, to a model.
    3 - Some Omega watches are specifically designed to get very wet. Some aren't.
    Speedmasters are WR to a certain level, but there are other watches that Omega make which are much more WR (dive watches like the Seamaster 300, Planet Ocean, PloProf for example).
    The OB staff were perhaps a little reticent of advicbg you to take your WR, but not heavily WR watches into prolonged periods of water submersion/steam.
    4 - If in doubt, watch Goldeneye. Steamrooms, Saunas and hot tubs are dangerous places, unless you're Onatop of things.
    GBTRIUMPH, River, watchknut and 3 others like this.
  18. jimmyd13 Jan 18, 2017
    If you intend using any watch in a hot tub, I highly recommend this £25 Lorus:
    I've dragged that thing through two oil slicks and untold numbers of other places far too horrific to name. I once had to replace the battery in it.
    On the other hand, just forget the watch and take one of these:
    Lonestar, Uniqez and watchme like this.
  19. korenje Jan 18, 2017
    at OB they told me you can swim in lava with omega watch. but from safety reasons they advised against it.
    NT931 likes this.
  20. korenje Jan 18, 2017
    well actually NBR seal can withstand 80°C. they probably use viton seals I assume which are even better. or maybe silicone which is even more temperature resistant.
    Considering that I work in food machines industry if heat was the problem all the gaskets would leak and nothing would work.
