My understanding of how these testers work is that there is water inside the pressure chamber but initially your watch is held above the water. You pressure up the chamber and wait 5 minutes, if there is a leak in the seals then the pressured air will go inside the watch. Then you immerse the watch in the water and slowly release the pressure in the chamber. If there is a leak then the pressurised air will leak out of the watch and the bubbles will show you where the leak is coming from.
And in theory no water should go inside the watch........but I think initially best without the watch inside the case
