Seems odd to me that seller is showing only the dial side of the movement (which seems to be properly signed). The other side of the movement should look something like this:
Also, I do not see any platinum hallmark on the case. I think that even in 1920's USA, some hallmarking was required.
If those two items check out, you can add a zero at the end of the current bid.
gatorcpa
