It isn’t, but that’s a common mistake that inexperienced sellers make.
Rolex had two series of case serial numbers from 1 to 1,000,000. The first one ended in about 1954 and they started over again. They reached 1,000,000 again around 1964.
https://www.bobswatches.com/rolex-serial-numbers
That watch has a early 1960’s look to it. Almost certainly from the 2nd series. There is a dated bracelet, although you can’t see the details in the pictures. Probably a dated case back as well, again, not visible in pictures. I’d want to see a movement shot also.
If all the numbers line up to 1960 or so, then it’s a really nice watch. However, I think that’s a “boy’s size” model, about 30mm diameter. Smaller than modern women’s watches.
Otherwise, it’s an expensive bunch of (maybe) Rolex parts.
gatorcpa
