Vintage Omega Geneve Automatic Help
Hi all,
This is my first time posting and my first foray into learning more about Omega watches. I'm excited to join the community!
My grandpa recently gave me his old Omega Geneve as a gift, and I would just like to get some opinions on it. I can't open the back so I don't know year of manufacture (even though the engraving on the back says 1977), serial numbers, or the movement.
But, if possible, I would like some help on the following points, with one leading into the other:
1. I can't tell if its stainless steal, solid gold, or plated gold. There are 2 engravings on either side of the body of the watch but I can't tell what they are or what they mean. The strap itself is worthless, he got rid of the original band a long time ago.
2. I'm not going to sell it, but ballpark what do you think the value is?
3. If it's not worth that much, is it worth getting serviced to clean it up? It seems like its working fine. I was going to send it into the Swatch service center in Toronto as I don't know any reputable watchmakers.
Thanks in advance all!
The combination of the gold colour with the steel back was very much used in gold plated watches, where the steel back offered more resistance to corrosion in an area at contact with skin. Given the marking between the lugs, would say 20 microns plated. A Geneve automatic probably contained a 563 or 565 movement, and probably dated somewhere in the 70s.
Would advise to go to a good independent watchmaker, not an Omega center. Parts can be found, and will be able to open it plus take images of moVement and inside back.
As for price, I am hardly an expert. But given that the bracelet is an aftermarket cheap item, would say the value lies in the 300-350 range. Worth to be serviced if you want to use a family piece, may be less importantif you want to sell. Note the gross damage caused by that bracelet on the lugs, hence the lower value.
Thanks! Maybe you have some insight into this question too: I want to replace the cheap band with an Omega band, does it matter if I choose leather or metal? I was talking with a person at an Omega boutique and they said not to use metal because it wont support the body? Not sure if that makes sense or not.
L Looch
I suggest that you give the watch a rub with a jeweller’s cloth and buy a couple of eBay leather straps and fit them yourself and see which colour and texture appeals to you before you splash out on an Omega strap.
I preferred black leather
I'm actually thinking factory service for this if they can source him a replacement case... those lugs are mightily worn down. Besides, other than sentimenta value, the're not much special in a Genève that merits avoidance of Omega service.
L Looch
Perhaps they were commenting on the large amount of lug wear from that watch-destroying bracelet. For your purposes, it's personal preference.
first and foremost i think you should go to a watchmaker so he can open the case - it will help a lot
it looks like a nice watch and to inherit a watch is always a good memory.
if you are going to wear the watch a lot i think you should get it serviced.
Thanks, ya from reading the comment I'm going to get it serviced
Thanks, could you explain a little more about this?
My further take is that it might be a mistake to spend too much on this watch.
1. It’s possibly worth £350-£450 on the open market in good condition and whilst a service is a good idea, sending it back to Omega will exceed the usual £80-£120 that I’d expect a service to cost (plus postage and parts). Even were you to source another donor case - it’s still a mid seventies gold plated Geneve and the financial value will not increase
2. At present it’s your Grandad's watch (and it’s nice to have the tribute on the caseback). If you start changing significant parts (like the case) it stops being your Grandad's watch and becomes just 'any' watch and your sentimental pride may be diminished.
L Looch
See answers below.
Sentimental value doesn't mean much on the open market. Also note he's in Canada, so the fantastic prices you Brits pay for service are not necessarily the same as he would pay.
Looch, factory service is generally fixed price and with a later movement like yours, everything worn out will be included. Once that happens, you're good to go for a long time and when you do get another service, fewer parts will need replacement. However, if there are issues with the dial or hands, Omega will replace them as closely as possible, but perhaps not the same. As for replacing the case, another alternative is to repair it, and this place is highly recommended by others here and is in Montreal: https://www.replateit.com
It's really up to you. If you can tell us what your goals are, we can help you fulfill them, from an independent watchmaker doing a minimal service all the way up to a significant restoration.
Omega service, by the way, is CAD550.00.
See answers below.
Thanks all for the support - I don't want to replace the case, or even repair it, but I do get everyone's points for sure. I'm ok with keeping the case as is. My overall goal is to have it serviced so I can enjoy it and pass it down to my kids if I have any. So SkunkPrince, getting it factory serviced is where I want to go. Actually as we speak I am talking with a store called Joseph Anthony in Windsor, ON who quoted me upwards of CAD800.00 for servicing plus replacement parts, which seems ridiculous but I'm new to this world
There are a couple of Canadian watchmakers on here, perhaps one will reach out to you.
