Hello, which tongue from modern OEM buckles do you use with the regular (non Omega) straps? I got Omega buckle with two different tongues. One is wide and nice (same width as the non OEM one), but has too wide base to fit in to the strap's end... Another one fit ok and I started using it, but the tongue is so thin that I have feeling it will excessively damage the hole on the strap after some time... What do you suggest? To modify the straps or to keep using them with the thin tongue? Image borrowed form chrono-shop.net
thanks, but I can not fit the big one to the strap in the place shown below... This is a problem (holes are fine – the big tong has the same diameter, only the base is wider..)
