These watches are not well received here, and for (mostly) good reason as they are usually pretty poorly made. Having worked on a couple over the years, the cases are crap, and the movements are usually in rough shape.
They are also not well represented with Omega on the dial, and in many cases they try to pass them off as all original. I will at least give the seller some credit for not trying to do that, and making it clear this is an old movement in a new case.
However taking a vintage pocket watch movement and putting it into a wrist watch can be done well. For example this movement:
Becomes this watch:
So if done properly, I obviously have no problems with this sort of work, but the result here is far from the junk made in the Ukraine.
