Hi All,
I get a lot of 321's with hour recorder issues so thought it a good idea to go through some of the root causes.
Disclaimer - This post is not aimed at self promotion, however I see no way to make members aware of the issues without relating my experience in repairing the 321.
The Omega 321 seems to have an awful lot of issues with the hour recorder. It's prone to creep and or lazy and inaccurate resetting.
First obvious issue is the hour recorder creep. This is where despite the chronograph not being active, the 12 hour subdial hand still moves forward.
To me this is one of the surest signs that the movement in question needs a service. You see, what generally causes it is not an incorrect adjustment of the hour recorder brake but rather a lack of lubrication in the clutch mechanism situated on top of the barrel. Too little lubrication = too much friction. Even with the hour wheel brake fully on (think parking brake or e brake in your car) the power from the mainspring is enough to turn it.
The hour recorder wheel CAN have flattened teeth causing slip where it meets the brake but its not common. Also possible is grease/oil in completely the wrong part of the brake, but again not common.
Throw in a weak - and out of stock for years return spring - and there are plenty of 321's with this issue.
Please note in the image below the clutch mechanism is hidden under the hour recorder bridge and is not visible.
Second issue is the lazy reset.
This one often has something to do with both the movement and pusher side of things.
What tends to happen is wear on the friction surfaces of the parts that form a connection between the pusher cap and the hour recorder hammer then subsequently the hour recorder wheel. These things work to prevent proper contact of the hour hammer lever face with the heart cam of the hour recorder and so causing a slow or ineffective reset.
The hour brake is commonly worn on the edge that rubs against the hour hammer lever pin. Wear in this area means there is not enough friction to give the proper 'snap' to the reset and so everything works kind of in slow motion. You press the pusher and the hand slowly returns to 12 rather than snapping back.
The hour hammer can have a worn pin which causes a similar problem. Or too much/incorrect lubrication. Or a rough/dry or both surface where it contacts the heart on the hour wheel.
The operating lever for the hour hammer can be worn at either interface, slightly bent, chipped or the wrong type for the case ( movement swap from a Deville or Seamaster )
Then on top of all this there is the gap between the pusher stem for zero action and the pusher screw. If this gap is too big it can cause the same whole problem all by itself. Important here to note is that the zero action pusher will often get caught up on the movement ring. Also this can cause the recorder to reset off centre.
All of the above on their own or in combination can cause the recorder to reset off centre or in a non consistent manner.
What this problem is not usually caused by is the heart under the hour wheel. Although it can become slightly flattened in some areas from use, it almost never needs replacing provided all the other parameters are corrected properly.
So,.... if you spot a Speedmaster, Seamaster or Deville with the 321 and it has either of these problems, you now know there'll be a whole lot of problem solving needed to make it right. Doubly so if these problems are occurring after a 'Service". If the seller says the hour recorder creep or reset can be cured with a simple adjustment, it almost certainly is not true.
It seems clear to me that a lot of services fail to address these issues, so beware.
I'm not sure how to add video's here or if its even possible but I have examples of the lazy reset and what it should look like when working properly!
Happy hunting!
