Hallo all, is it posible to change only the black tension ring ? The old one has on the right side a 2cm long gilt scratch. Importend is,this speedy has the flat plexiglas from 1971 on it. Thank you for help.
Yes, you should be able to fit the black armour ring from any Speedmaster hesalite crystal. You’ll probably need to buy a complete crystal in order to obtain the ring as I don’t think they are available separately.
If the glass is still in the watch. Can I then pull out the ring? Or does the glass always have to be completely removed? Many Thanks
